More viewable resolution needed in CMY
Working with DL.2 a lot recently has led to some frustration that we cannot view the full set of 0>255 values in CMY.
Right now we can see 0>100%, but for example when setting up a DL.2 collage 1% on the Magenta (or Mod2) could be one of many grid cells in the collage. Or for that matter simply the Cyan (Mod2) to select which collage array is to be used.
This makes it almost impossible to create cues in blind or set up palletes offline for this stuff. The only pain-in-the-rear workaround I've found is to find out what DMX channel I'm working with and view the value in the DMX values window. This is FAR from ideal.:aiwebs_007:
So maybe we can have something like 0.2% or 10.3% displayed to get those other values in there. PLEASE!:D
