Remove DP from show patch
I had an instance were for a short while I had to add an additional DP to my show. I also use start-up macros when my console is turned on. Once I no longer needed the DP I removed it from the network, but the start-up macro is looking for the DP that's no longer there and will not run until the default 10 mins up.
My question is, short of doing two show files were 1 has 1 DP and the other has 2 DP's, can there be an option to delete a DP once it is no longer needed?
