using touch when a cue is paused
I have the following issue:
a cue is paused running from cue 1 to cue 2 at for example 44%. selecting fixtures and using touch results in the values programmend in cue 2. I think touch should result in a capture of stage at that moment. but correct me if im wrong. The workaround is of course to actually touch the parameter wheels but is that the best solution ???
Greetings
Frank Verbeek
