fixture part patching
Today I had to patch a fixture part for the first time on a H3 and found the point and click method quite cumbersom for someone who is used to doing as much off the command line as possable. :poke: I would like to have a double press of the @ key allow me to patch the fixture's second part. Foe example patching a color command: 1@1 (would patch intensity at 1) then 1@@2 (would patch the fixture at 2).
  • I wonder if there were a way to combine this action into one single keystroke sequence. User #@Intensity@(this currently puts it at a level if I'm not mistaken). But maybe something like User #@Intensity.Fixture whereas you could also specify what universe these items we're going into as with a scroller dim for instance the intensity and scroller are many times in different universes. This would be amazing if there were a way to combine this into a single keystroke sequence.
    Eric
  • Maybe like using the actual Intensity / Fixture keys? I like that idea. So the seq would be something like (for a scroll dim) SCROLL DIM 301 INTENSITY @ 1/1/54 FIXTURE @ 1/2/10 ENTER.
    Anyone?
    EB
  • Eric,
    I think your syntax idea is the most logical option. It gives users a way to patch one or both fixture parts directly from the command line using intuitive syntax that fits our current model.
    I've added your comments to enhancement #2986.
