HI,
Is`t possible to get a tracking sheet ? So for example if you say fix. 1 thru 3 enter. You wil see fix 1 thru 3 in a sheet and here you can see in wich cue it`s used. also you can say i want only see the information pan,tilt and magenta so you can filter the information. If you do shows with 200,300, 500 etc movinglights than sometimes you don`t know if spot number 203 is used in 80 cues before the cue you want to make. if you have a sheet where you can see where this spot is used and with kind of information that will helps you a lot.
