Is there a way to change the order of the different modes on parameters? For example, I can't count how many times I have selected Beam then moved the Gobo <> parameter wheel only to notice after I touched it that the "mode" for that parameter was Index instead of Rotate. There are many shows where I am not interested in the Index mode so I would like to be able to put the Rotate mode first. I am using the Hog3 PC v2.2.2 (b1809).
Kevin Montagne
kevin (at) litkam (dot) com
