Profiles
I ran into an issue when using the Pixel Line Micro W profile. First off it took a few minutes of fiddling with the fixture to figure out which mode the profile was for. Maybe we could have some sort of notes on a profile to indicate what mode the fixture needs to be in and any other special mode settings to make the fixture talk.
Also, this fixture uses RGB and A for color and the profile lists CMY and I had no access to the A.
