Editing Cue Fade Times
Occasionally I want to edit the Fade times in a cue that already exists.
Like change the Position Times.
I go CUE 1 COPY ENTER to bring the cue into the programmer.
Then I edit the fade times.
I then do MERGE CUE 1 ENTER
But it doesn't merge the Fade Times into the Cue :confused:
The only way I can get it into the cue is to SELECT ALL, TOUCH, and REPLACE the Cue.
If I edit the Intensity it MERGEs ok.
Bug?
I have seen this for the past several years, but just never got around to asking about it.
Should I be editing the Cue Fade Times a different way?
I thought of this again because I was testing the new MARK feature.
Cat
