2.3.1 b1932 Park
Just a qustion, is this normal when I pig +park from the parked window for the Object Changed window to pop up asking Park has been changed by another operation would you like to Ignore or Reload :dunce:
  • Yes, that is normal. The parked window is an editor and when you attempt to make changes to the contents in that editor from OUTSIDE of the editor (such as Pig+park) the editor needs to know if you want those changes to be loaded into the editor or for those edits to be ignored.
  • Well ok then it works another question were any othere updates made to this build ?
  • A few important bug fixes:
    4663 [pig] + [park] does not work correctly all the time
    6265 Parking will park everything in the programmer, but only remove selected
    10984 Auto-Update selections can get into an odd state.
    11357 Unpark is Broken in v2.3.0
    11358 Hog iPC monitor configuration problem on certain motherboards
    11359 MAC Address display in console Network window invalid
    11360 Unparking should bring parked values into the editor
    11361 Auto-Update does not allow cues/palettes to be deselected
    11364 Console monitors get swapped when keyboard layout is changed with external monitors enabled
    11365 Parked editor should not be able to be auto-updated
    11368 Chinese Fonts incorrect on XPe builds
  • Grate stuff it's been working wounderfuly at CES Las Vegas for Peter Frampton and Rocco Deluca & the Burden.
