Depending on what you have in the cuelists, you can turn them off and on a couple of ways.
If it's a single cue, you can add a release cue at the end. You can hold down the button and press the release button on the console (mentioned above) You can write a second "list" directly below the running list with a RLXXX comment macro.
How I set mine up is each row has 12 lists. 1-11 are actual lists. List 12 (last one in the row) is a "RELEASE THIS LINE" list with a comment macro to release lists XXX-YYY. On top of that, I also have on lists 13-23 individual lists to release the one directly above it.
List 13 releases List 1, List 14 releases List 2 and so on.
Hopefully that makes sense. If not, let me know and I can take a screen shot showing you how mine are setup.
quote : " You can hold down the button and press the release button on the console (mentioned above)"
Not run on HOGIIIPC : On the hogPC software you can hold down a button with shift but you can't hold down the cuelist button and you can't hold down the Release button
