Software Version and build number: iPC / Hog3 v2.3.0
with XPe Image (the one before) 8.1.0 from January 8, 2008
Number of displays: no externals
Connected USB Devices: 1x miniwing
Hey there
while being bored in the standby time i noticed something really strange.
all the cuelists on the main playbackbar programmed at this time suddenly began switching to off state and back to their normal state in a random pattern.
masters 2>6 were set to cue1 (all LTP at this time) - master1=GM - but they randomly began jumping between (...) and cue1. GM was not influenced. i didnt watched the cuelistview so i can´t tell if it happend there too.
The good thing was that it didn´t changed the output values. on stage everthing was ok. this happend a few times and i´m pretty shure that i didn´t touched the console in this moments. and i have no idea what could be the trigger.
during the following programming everything was fine and the problem dind´t show up till the end. it was not reproducable.
back home i also tried to reproduce it on my private pc with Hog 3PC
.. nothing
i read someting about HTP faders getting stucked in a thread. this also happend to me the next day.
i wanted to merge intensitys of generics to a cue but it didn´t work. pushing up the HTP fader the cue didn´t change. i trying to replace the cue also didn´t work. even when i deleted the cue out of the list it was the same result again. an error massage showed up: something like server busy.. first when i deleted the cuelist from the master and put the empty list back on i could record a cue in a normal way.
hope this helps to find the bug that really made me feel uncomfortable this evening
regards
thomas
