Expansion Wing Playback Bars
OK, I'm sure I'm being stupid here, I can get my playback bars to show up on the playback wing (10 faders) -- How do I do it for the full size expansion wing? Way to many faders to keep track of cuelists on.
:hogsign:
  • Hi,
    used a big wing recently and from what i remember it is much the same as a 10fader USB wing except it splits the big wing into 4 wings.
    Top left
    Bottom left
    Top Right
    Bottom Right
    you would select as per USB wing,so wing "1147" would be top left,"1148" would be bottom left etc etc,
    Only issue was keeping the wings in the correct order after i re-booted the IPC the every day but i'm sure that was me rather than the console.
    Fantastic thing to have at a festival and made my life so much easier being able to lay everything out on one page.
    C
  • Stephen,
    As Cormac says, the configuration is very straight forward. It is also detailed in the User Manual section 12.4
  • I figured it out; I didn't have my ext screens attached, and they were showing up on the right monitor that didn't exist!
