(1949)Bug Report: IFCB don't recall values after clear
Date:29/02/2008
Software Version and build number:V2.3.2(b1949)
Number of displays:0
Connected USB Devices:0
Networked Devices:1 DP2000
In master 4 I have an cue with fixture 1 @ full and some Pan/Tilt values, IFCB mater option is selected
1) I put the master of the list at full and after I put it at a value between 1 to 99% (values are purple in output window so in release state), dimmer and pan/tilt have some values defined by master position (values are purple in output window so in release state).
2) I put dimmer of Fixture 1 @ 0 in programmer.
3) Clear
The dimmer stay at 0 as it should come back to fader 4 value.
It is the same if i put any values for dimer in programmer.
I also made the test with Pan/tilt it is the same for all parameters.
Steph
