Does anyone have any tips/tricks on programming LED Battens (specifically stagebars) on the Hog3?
I want to set a base colour (for example blue) and have random strips of another colour (for example green) run through it .
Diagram:
Green moving >>>
||=Blue
::=Green
(The diagram represents a row of stagebars)
When would you use, HSI as opposed to RGB? Which is the easiest to work with?
I posted a similar question to this on the LN, but didn't get an answer. It would be much appreciated if I could get help here.
Cheers,
Jared
