As Marty says you can use MIDI Show Control (MSC) commands to trigger Hog 3PC. You can also send MSC commands as well as any MIDI system exlcusive commands (including NOTES) via cuelist macros.
For your Hog 3PC computer, you will need a MIDI card or USB MIDI device such as the 1x1 or 2x2 (or other models) from M-Audto: www.m-audio.com/index.php?do=products.family&ID=midiinterfaces
You can buy these USB devices at many computer or music stores and lots of on-line retailers.
Hi Chris, Can you expalin how you route your MSC to FOH console or do you have a console at FOH in your set-up I am trying to design a system and have got to the point where i would have MSC onstage and have read of several methods of routing MSC but am not clear as to the most direct and effective route. If i had a networked consoles in place would both consoles see MSC or or is that not the case,my idea being one console onstage one at FOH? Do you need to boost MSC signal if it is going to FOH or over a certain distance.
If you have multiple consoles on a network, then you can plug in the MSC to any console on the network. Then you simply specify that console to be the MSC Source for any other networked console......same goes for LTC/SMPTE.
