Hi there,
I work for several big fireworks and use smpte with Ipc (Hog3pc Mode).
As there are not offset command to adjust cuelist with timecode I used wheel encoder on Hog2. (select all cues and "set" and turn wheel until I have good time adress for cue. Result all others cues was "offseted")
I search this fonction on hog3, seems be disapear.
Any Idea?
(I have between 200 and 400 cues so impossible for me to enter new timecode adress for all of them)
Thanx
