I am Using a RoadHog (v2.5.0 (B2063) ), and have noticed a problem with editing cuelists on stage.... if I abort the process without updating, it seems to freeze the cue I was working on onstage, and will not let me Clear it or Release it.
for instance I select: list 4/1> open, alter something, and then decide that it does not work or get distracted or whatever, and then choose to abort the edit, when I press CLEAR nothing happens, when I press PIG+Release, nothing happens, Choose and Release, trying manually alter the lights, nada...
sometimes after several minutes the Cue will mysteriously clear, today I went  so far as to Delete the original cue (it was a simple cue and easy to rebuild, but that is not the point...)
any insights would be appreciated...
TR
