IPCB Fader for GOBO Rotate
Console: HOG III
Fixture: MAC 700 Profile
In the last six months I've done 3 different fundraiser/festival gigs that we setup the console in a busking type mode.
In doing this I had one fader for GOBO Rotate Speed.
I recorded a SCENE with the rotate at say 70 rpm.
I then moved this scene to a fader, and set the fader for IPCB crossfade on the main.
It works fine except the fader releases when pulled down all the way.
The rotate returns to the index mode and the gobo snaps back to its default position.
I played around with some different settings to see if I could stop this but didn't find anything.
My solution was a small piece of gaff tape to prevent the slider from going to the bottom.
Thoughts? Solutions?
"Cool as a moose"
Cat
