RoadHog Restarting by itself?
Console: Roadhog
Software Version: 2.6.0
Problem: Console restarting...see below
The console just randomly decides to restart without an unplugging or switching, or the software way to restart. It did this twice. The first time, which I was there for, I typed:
101-106@full
Pulled up palletes, then the color picking wheel, then pulled my finger from around center to a full blue..walked away, and the console restarted. When I came back, the console was on the login screen. I asked the other tech's on site, and no one had reset it, or kicked power or anything similar.
The other time, I was not there for, but I hear the console just went black and started back up (like a power failure).
Any thoughts? We had the console plugged into a courtesy on a dimmer, with a power source that was constant house power: metered showing 119-121 VAC on the outlet.
EDIT: The cable on the console was checked to make sure it was all the way in, and I checked all the connections between the dimmer and the console to ensure there were no loose connections.
