Is there a way to set the time for a single cue so that updates take that time by default. In particular, suppose I write a cue and then set a time for the overall cue by typing "Cue 1 Time 4". Later I decide to add another fixture to the cue. That fixture is assigned the default cue time which is set in preferences rather than the time I assigned the cue, so the cue ends up with split timing. Is it possible, once I have assigned a time to a cue, to use that time instead of the global default?
On a related note: (this is probably an enhancement request) Suppose I have already set the cue time to 4 secs. One fixture has a time of 20 sec. Now my time is "4s, 20s" where 4 is the time for everything except the one fixture. I would like to change the cue time to 5 secs without changing the one fixture that I have set to 20s. In other words, "Cue 1 Time 5" sets the global default time for all fixtures in the cue that have not been explicitly set to something else. How would I do this?
As long as I'm asking for the stars, suppose I have 20 fixtures set to the 20 sec time in a cue with a time of 4 sec, how about a way to change the 20s without changing the cue global time.
