Hi Ya'll
Having some trouble with efficiently allocating times for effects in cues.
It would seem sensible to me that when creating an effect that you should be able to click on the spreadsheet Fade timeslot, in the effects engine, and allocate a desired time.  Yet whenever I do this I close the effects editor, hit clear, reopen the editor and the time I changed has reverted back to the default time.:aargh4:
What gives.  As I see it the real strength of hog machine version 3 is the spreadsheet editing feature.  Why is it not available in the effects editor timing?  Did I miss something obvious?
Also looked to command line syntax to get around this problem.  However when using the syntax as described in the manual ( Effect Time [value] ) whilst in an editable editor, this does not work.  :17: This problem is discussed in the thread titled "Effect time entry" dated Aug 2008.  It states that this command line feature has not actually been integrated into the software yet.  Logged as bug #4924.  There is not however a mention of this bug being resolved Hog PC 3 nsoftware ver 3.0.:nono:
So what is the best option here?
I have noticed that the cue time seems to control the effects time as the cue is executed.  So now I am creating extra cues with wait times to get around this problem.
Please tell me of a more efficient method as I do not want to create these extra cues with a wait time to get around this problem.
Wastes time!
:1zhelp:
