I have a customer running an iPC that is experiencing flickering outputs from dimmers at 0%.  If he gives them an intensity value of 1%, the problem disappears.  It's a permanent install and they have the iPC connected to their Lectrol dimmers via a Pathport network.
He said an old remedy for that problem was to adjust the DMX refresh rate of the console, but he didn't see anyway to do that in the Hog 3 manual.  I am wondering if it's a dimmer issue or perhaps noise on the Ethernet line in the Pathport network.  I don't see how the console could be causing it unless there is something to the DMX refresh issue.
Anyone else dealt with a problem like this?  Thanks in advance.
Travis Slyter
Ruehling Associates, Inc.
