Hi, What's the easiest way to download 3.0 to a USB stick and load it into an IPC ? I have a MAC. Also, can you save more than one show file at a time to USB ?
You cannot use a bootable USB drive onthe iPC only on RH & RHFB
Full install/re-image of an iPC must be done via CD.
LA,
Download the iPC config panel, and H3PC software. Expand the zipped files onto your USB, then first upgrade the iPC config panel, followed by the H3PC software.
If you plan to use DP-8ks with you desk you will need to download and install an additional piece for this.
Honestly woth v3 you would be better off re-imaging your desk with a Full/Clean install. Just make sure to backup your showfiles externally first.
