i would like to connect the wholehog 3 with wysiwyg 22 i used a hub i connect the wholehog 3 and my pc on the hub and after , i don't know what configuration for wholehog 3 and pc used please help
You connect in exactly the same way, just substitute the console for the H3PC app.
As far as physical connections go, either run a crossover cable directly between the console and your computer, or use straight cables and and ethernet switch to connect everything.
