How can I knockout a single perameter using only hogPC (no wing) -- normally i'd hold knockout and turn the encoder ... can't figure out how to "hold" the knockout key (tried shift). Any ideas?
If you get lonestar encoders (another thread on here) it is an app that will map a shift button on the front panel so you can click that and the backspact then touch the wheel and it will clear that parameter. Its a very handy little app to have. It also adjusts the sensitivity on the wheels so it is way easier to work with.
