I am having issues with the clr changing functions in hog 3 on the ipc.
when changing from magenta on the mixing flags to cyan, the fixture (mac 2000 wash and mac 2000 profile) on the mixing flags, it go's through white.
some clrs on the mixing flags are jumping or ignoring the default cue fade times.
is this the path, they are on default linear.
is it the console, ipc running hog 3
or is it the fixture, mac 2000 wash and profile in 16 bit.
I have just moved over from hog 2 to 3 and have never seen or had this problem in hog 2 mode.
please help.
