Full Universe of LEDS
Hi All
Just wanted piece of mind really, about to do a show where one of my universes will be full of LED fixtures. Anyone had any experiences with the amount of LED on a RoadHog. Will it cope ok with effects chases etc??
Cheers
S
  • I don't work with the regular RoadHogs much, but I wouldn't be concerned. There is plenty of processing power there.
    It would only worry me if you were using a DP-2000.
    Hope this helps. :)
  • [quote=skier;39652]Hi All
    Cheers
    S
    Hi Skier,
    I have just finished a week with a Full Boar and it was very fast. I dont think you will see any speed problems whatsoever with the Road Hogs.
    [quote=Marty Postma;39653]
    I have started to go off the rule of 1024 LTP channels on a DP-2000 to make sure I am not hit by any speed issues.
    Best Regards,
  • > ...a Full Boar which (to my knowledge) has the
    > same processor, motherboard etc as the
    > Road Hog and it was very fast.
    The RH ahd RHFB use different processors and motherboards.
    Road Hogs use Celeron-D series processors, and Full Boars use a Core 2 Duo.
  • [quote=ericthegeek;39674]> ...a Full Boar which (to my knowledge) has the
    Hmm. I have used both and never noticed any difference in speed. Then again a FB can process more. Either way Eric, I think both are great! You guys certainly did a good job whatever is inside them!
  • [quote=Joe Bleasdale;39664]I have started to go off the rule of 1024 LTP channels on a DP-2000 to make sure I am not hit by any speed issues.
    I personally would cut that number in half for HTP channels, and make sure that that is the only thing on that particular DP.....and even then I'm sure I would find a way to make the DMX output "hiccup".;)
    FYI....no such issues on RHFB or DP-8000.
  • [quote=Marty Postma;39683]
    Hopefully by next April, I will have bought my own Full Boar AND DP8000. I absolutely love them!
    Best Regards,
