WholeHog 3PC & Daslight
So i'm learning the Wholehog system very well now, but i would like to send the midi outputs from the Wholehog system in to my Daslight program on the same computer to get it working with the visulaiser.
Is this possible to send the midi around the same computer, and is it possible to send the output of the Wholehog desk to another devise?
Thanks for you help, David
  • I haven't tried it,
    But I hear Midi Yoke will do that.
    www.midiox.com/
    Good Luck,
    Joshua Wood
  • MidiYoke is an awesome, little, program.
    I have not used it to 'out' midi from the Hog, but I used it to get timecode from Cooledit Pro into Hog2, although I have not tried with Hog3. But the program works a treat.
    Hope it works out for you..
    Mike
  • Most visualizers require the DMX data from the console, not MIDI data.
    The Hog Visualizer Connectivity driver ( www.flyingpig.com/support/hog3/downloads/archive/wyg/VisualizerConnectivity.shtml ) lets you directly connect Hog3PC to a supported visualizer. It supports ESP Vision, WYSIWYG, Martin Show Desinger, Capture, and Light Converse, but does not support Daslight.
    If you're trying to learn how to use the Hog, then consider downloading the demo version of one of the supported visualizers. That will let you run a virtual show without any additional hardware.
    If you want to use Daslight, you'll need a Hog console that supports Art-Net, or a a DMX Widget to output DMX from Hog3PC, and a DMX interface to get the data back in to Daslight.
  • Hey, thanks for you replies. I might look into WYSIWYG, i know lots of people use it.
  • You could also look at Light Converse. LC has the best graphics I have ever seen! And I have used WYG, MSD, ESP and others too. Nothing compares. I have an unlimited version with me now on extended demo. I have been running it with H3PC for a few months now. It goes back at Plasa time, I will be sad to see it go. Awesome piece of software.
    Regards,
