I-Wheel Intensity Issues
We have noticed when using the I-Wheel on our WH3, that if you grab a set of fixtures and roll the wheel down (with the intention of bringing the fixtures to zero, the I-Wheel will hold a neg value (while only displaying 0% on the output) and then if you grab the next set of fixtures while that wheel is still spinning, it will delete it off the programmer / command line as the wheel is still spinning..
I mean honestly who grabs the I wheel to bring it to exactly 0%, I know we all grab it and thrust it down.
If there could be a way to make it where the I-Wheel only works for fixtures that were selected when it started moving, and any added after (while rolling) are exempt from it.
