HTP lists holding over even after Pig - Release
Hi
I'm having the following problem:
If I record a HTP list that only has intensity information and have it on a fader occasionally it stops being active via the fader and will just hold the intensity. Also say you have the fader at full when it holds over if you then take the fader to 50% and hit the flash key it will then hold at 50%. Weird.
I can't pinpoint how it accrues though. I thought that maybe because I have a state recorded with that information in was the problem but when I delete the state it still happens.
I have tried the follow to correct this:
Release - NO
Pig - Release - NO
Delete playback - NO
Delelet list from List view - YES
Control via GM - Yes
Control via Programmer - NO
Please help. Has anyone else come across this?
Frustrated
Rob
