ETC - Community
Site
Search
User
Site
Search
User
Control Consoles
More
Legacy Consoles
Legacy - Wholehog 3
intensity/strobe problem technobeam
More
Cancel
State
Not Answered
Date
sosumi - Former HES Forum Member
Date
Mon, Nov 2 2009 9:06 AM
Replies
Subscribers
3 subscribers
Views
Users
0 members are here
First of all, strobe in the effects engine does not work for some reason. When I try to select Sine for example it doesn't do anything and just goes back to an empty gray box. I can't automate strobe at all.
I try to do strobing with intensity instead -
When I set up the effect - pan and tilt on sine waves and intensity on a step wave with 200 cycles/minute, it looks fine.... then I hit Record, 8 to save it to a cue, then I clear the programmer. I go to play back the cues and when it gets to cue 8 it's the right color and they're panning on the sine wave but not flashing at all (intensity not working). When I "view cue" i see a picture of the sine wave and 100% in the intensity column. Dunno why this isnt working.
In order to make any Intensity effects work I have to go to the keypad and hit @ 100 ENTER. then the intensity effects work. however after i clear out the programmer and go back to try to play the cue again it doesnt work until I go do the @ 100 again. This applies to the palettes too, when I click the palette with intensity automation it only starts to flash after I do @ 100. Any ideas how to get around this?
0
bradpepe - Former HES Forum Member
over 13 years ago
Sosumi,
It sounds like there might be something else playing in your show file. Can you send me a copy of the show at upload.highend.com ?
thanks,
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
robbie_bruce - Former HES Forum Member
over 13 years ago
What version of software are you using?
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
over 13 years ago
3.1.0 b2672 on Vista 32 bit
still can't figure out also why i can't do any effects on the strobe param of the technobeam... i select anything in the dropdown for the effect shape and it just goes back to a grey box
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
rautasami
over 13 years ago
Do you have any values for strobe? You cannot apply effect without a base value.
Choose Technos, press intensity and adjust strobe parameter (4th wheel) to 3Hz for example. Then go to Effect and choose table.
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
over 13 years ago
[quote=srautane;42400]Do you have any values for strobe? You cannot apply effect without a base value.
That seems to have fixed it!
Still not sure what's going on with my intensity automation... probably something somewhere overriding it just not sure where.
Sorry for the amateur questions - this is my first attempt at any kind of light programming whatsoever :/
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
rautasami
over 13 years ago
You could try first releasing your running lists using PIG+Release and then running only the list which has the effect.
Also you can check your cue...pressing Choose of your master where the list is and then typing Cue 8 Open. Press Blind off to see the cue live.
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
