3.1.x Bugs
Hey, these are a few small bugs that I have noticed after upgrading to 3.1.0 (And some are unfixed in 3.1.1)
1) I-Wheel, If I hit 1 (Enter) to select fixture 1, and then use the I-Wheel to adjust the intensity, it wont show a value in the programmer, how ever if there is all ready a fixture in the programmer it will... so its only the first fixture.
2) Timecode Cue, Sometimes it will fire the cue, and then like 3 cues later, the shade of the box will turn white as if it was not fired. then some cues later it may or may not change back to shaded.
3) Flicker, It seems like some of my cuelists in the cuelist pallet, are flickering more...
4) Grey Bar, it seems like there is a grey bar going across my screen.. of some of my output views.
I will post some pictures later.
  • Ryan
    A few questions for you.
    1. What fixtures are you using. I am having no problems calling up a generic RGB LED's in the programmer using the IR IG IB encoders.
    2. I will look into the timecode not triggering cues.
    3. Is the 'Flicker' in the output window, programmer?
    4. Can you tell me what windows you are seeing this grey bar in?
    We do have a grey bar in the programmer in the 'Num' column, is this what you are talking about?
    What is connected to you Hog 3's and how many?
    DP2K, DP8K, playback wings, ext. monitors
  • [quote=michael_graham;43089]Ryan
    1) Its only with the I-Wheel, the Encoders seem to work fine. This goes for any type fixture, Mac 500, 600, Desk Chan, Non Dim, RGB LED ect...
    its only for the first fixture on the list too, as soon as you add a 2nd fixture to the programmer, it will show the value.
    2) It looks like its triggering, just not displaying that it triggered.
    3) The flicker is in the cuelist pallet / display
    4) The grey bar is running horizontally across the screen in the Current Cuelist window and in the output.
    I apologize about the picture, I forgot to take my camera into the venue.
    I will make sure to take a few pictures during tonights show..
    These are all still confirmed in 3.1.1
    This is on 2 different WH3 with a DP2k
    I have 2 WH3 each with one DP2000, each Hog has 2 External Screens (15" 1024x768) and each hog has a USB Timecode Module. No MIDI, No Wings
  • Ryan
    When you get to the venue tonight, can you make a copy of your show file and send it to us?
    1. Using the I-Wheel I am having no problem with values showing in the programmer.
    2. We are looking into this, we have seen this once but can not nail down a repro.
    3. Will look into this some more.
    4. Please take a picture of the grey bar, I think you are talking about the DARK GREY line. To check open the programmer, is the grey bar aligned with the word 'Num'?
  • I have a backup of the showfile made today, and I will upload it with the pictures later tonight.
    as for #4 it may be that grey line, Im not quite sure, I will post back
    I will also post a video of the i-Wheel issue as that might help
  • Thanks, yes a video would be cool!
  • Ok, I was able to get a good video of the i-Wheel issue...
    Here are a small example of the T/C Issue (This one just shows it as a manual cue)
    The 2nd image is a few cues later... sometimes it fixes its self, sometimes not.
    img137.imageshack.us/img137/4461/timecode1.jpg
    img136.imageshack.us/img136/1301/timecode2.jpg
    Here is video of the i-wheel
    www.youtube.com/watch?v=O7SHzI5Md1g
    whats odd is the i-wheel is only doing this on one of the Hog's, not the other...
    ITs giving me some errors trying to upload the backup file.. Ill try tomorrow when I have a stronger internet connection
  • Ryan
    Thanks for the information.
    When you can please send us your show file.
  • Ryan
    The I-Wheel problem is a redraw bug.
    Try sorting by type again to see if that will fix it.
  • Michael, I will check the i-wheel tonight as we have two shows,
    but here is the hog file for the one with the i-wheel issues, I did not have time to grab a backup of the one with timecode cells missing.
    Uploading the .tar.gz file on here keeps giving me a failed. I will put it on a website I have and post the link when its done.
  • florida355.com/11-19-09.hog3.tar.gz
  • www.youtube.com/watch?v=-29F2qtg-vM
    The flicker is almost on a diag up the cuelist window...
    Lamp On (16)
