Hog 3 CUE Question
Hey everyone i am having a problem with some cue structure and i figured someone here will have the answer to my problem. I am running a Hog 3 in version 2.3.1 (b 1932). My problem is this : I have a light tracking across stage and then several other cues firing while this light is moving. (All of these cues are firing on the same fader) When the other cues fire my light seems to be programmed in a differnet position causing the light to move faster then it needs to. How do i knock out these other positions that were written in these other cues? I just want to clear the position values on those cues so that light does not track faster then it is needed to. I look forward to everyones insight.
Richard
