live time
Ok so how do I tell the console to do fades with palletes during live shows. I have tried doing things like pos, time 3 enter or like live time 3 enter or time 3 For example, But It just doesnt seem to work right. What am I doing wrong. Also you know on the etc consoles where you can bring up a sub and record that and the cue will take it is there a way to do that on the hogs?
  • You can put a look and a fader and use live suck to grab the values from it but they will not 'jump' into a cue.
    There might be a better way to do timings than this but here is my take on it. Pop into blind, make the changes and then hit time X. To fade the changes hold pig while you hit blind.
    This work around does not work if you are building on a look in the programer, when you go into blind you stop the programmer from outputting to stage.
  • Live Programmer
    Hog 2: Press Live Programmer in the Control Panel to toggle on/off
    Hog 3: Press the Fade Changes button in the programmer window to toggle on/off
    Then the palletts will fade
  • Ok so after I do that what is the command line I need to type to have it fade at the time I want. I had called tech support about it some time ago and they told me set up preferences default timing and programming and He said that when I changed the times under that it would fade at the 3 seconds when I called it on the fly. The problem was three months later (yesterday) I had to do that and It didnt do ***. I got stuck on a dance rectial with 6 250 kryptons and 8 led pars. 3.5 hours to program 46 songs I think I did like 85-90 cues in that time with no tech rehearsal for it so it was a challenge. Sorry for delayed response I was checking on here to write to high end and tell them there method failed lol.
    [QUOTE=MLorenz;45310]Live Programmer
  • When you are in the Live Programmer mode (fade changes) and you give the command "Time X Enter" then you can fade to a pallet in the given time.
    Example:
    "Time 20 Enter" select your spots and hit a pallet (colour Red). Your spots will go to red in 20 sec.
  • You can map "fade changes" to one of the buttons around your trackball - I have mine on top left.... makes it easy to switch between modes...
    if I want a smooth position fade I'll select the group, push time, then turn up fade time on the first encoder wheel, then choose my position...
    the fade time will be remembered if you flick between "fade changes" on and off...
  • If any one reads this if youll havent tried it try doing pos time time 0>3 enter Lets say and then select your fixtures and tap the your pallete, cool little trick.
  • hey guys, so ive been trying those above tricks n it'll work only on I,P,E but not C or B..is it bcos theres 2 gobo n colour wheels?N maybe theres a different syntax command for B n C?? im running on hog3pc-V3.1.6 n robe xt 575s n 250s spots..thankd in advance-DIDI
  • Gobos and fixed Colors are set to Snap
    So thats Why you don't See any fades there, try with iris and you will see a fade
  • If im not mistaking some moving lights have a color time to on it so if you just tap through the pallete menus you might find something.
    [QUOTE=fruitcake;49099]hey guys, so ive been trying those above tricks n it'll work only on I,P,E but not C or B..is it bcos theres 2 gobo n colour wheels?N maybe theres a different syntax command for B n C?? im running on hog3pc-V3.1.6 n robe xt 575s n 250s spots..thankd in advance-DIDI
  • [QUOTE=codystoltz;49309]If im not mistaking some moving lights have a color time to on it so if you just tap through the pallete menus you might find something.
    Cody,pallete menus?
  • Yeah you know how to change the pages on the encoders to control different paremeters by tapping the pallete buttons
    [QUOTE=fruitcake;49381]Cody,pallete menus?
  • [QUOTE=codystoltz;49389]Yeah you know how to change the pages on the encoders to control different paremeters by tapping the pallete buttons
    Oh yeah! got it thanks thanks
