For Hog3PC midi I/O I recommend the MAudio 1x1 but there are several USB midi devices out there. As for midi controllers that send midi notes, you can't go wrong with a midi keyboard but again there are midi note software applications for your desktop out there as well.
Hi, i have doubts as to how to install my device of midi notes, already try put to work and nothing, i have a console Beheringer BCF2000 and communicates in a midi by means of USB, at least so and done in programs of illumination and audio, ojala anyone could help...thank you
I have a m Audio Usb Uno and I'm desparately to make it work on my windows 7 64-bit PC. I says it sees it but I can't get timecode it. I set all the relevant boxes as I would on the Full Boar but to no luck. Am I being really stupid. I need to get it working as my back up for a big timecoded show. Thought it should work.
Best wishes,
Nigel.
What are you trying to do with this? Are you trying to get LTC into H3PC? If so the only way to do this is with an LTC widget.
The only 3rd party hardware that will allow you to input timecode would be a MIDI device for MIDI TC.
does anyone use midi note software applications for your desktop (pc)? if so what are you using?? I am contemplating that or rocking a Midi keyboard. What keyboard are people using? what seems to work well?
I set on the basis of the supplied images HOG3Pc the driver to be controlled by a Korg NanaKonrtol2 MIDI controller, but for some reason can not control. My question: What could be the problem. Each would be asked to help because it would be very important. Thanks in advance.
