Hi everyone.
I´m new here, and i need some help with my hog3.
I´m starting to program a new show, and suddenly my hog3 started to have problems.
I start the console, and a few minutes later, both screens go off.It looks like it´s only a problem with the screens, because the playback wing still change the chooses, and the image in the external screens is good. 3 or 4 minutes later, all the chooses of the console start blinking, and the console is completely off.
I have change the power, because i´m at home programming, and i have a lot of things conected. I thought it could be power problems. No it isn´t.
I´ve disconected the expansion, the external monitors, also the ethernet cable, and keep failing.
Right now, i have the console open. I did some preasure on all the conections thinking in some conections failure. I have the console running, and it looks good, but... i´m afraid because if it is a real problem, it will appear again.
I´m running 3.1.6 (2773), but i don´t think it´s a software problem.
Thank you very much.
