Network Setup and Remote Focusing
Up to now I have only used the HOG III with one DP 2000.
I want to make sure I understand network setups before I proceed.
My show setup will be a HOG III and a DP 2000.
However, for programming I want to add a HogPC on stage.
The room is in the round, and all aisles lead to the stage.
Therefore, it is hard to do aisle focus points from FOH.
So, for programming I plan on using
HOG III in "Use default IP setting" mode, and "Enable DHCP and Boot Server"
A 4 port router with wireless, with it's DHCP turned off
DP 2000 set to obtain IP via DHCP
All on Port 6600
HOG III as the show server and console 1
plugged into the router with a non-crossover.
HOG PC with Run Server off, as console 2
on the wireless.
When I'm done programming I go back to the crossover cable straight into the DP 2000.
Am I close?
