Artnet to Hippotizer
Howdy all,
in a bit of a stick and hoping one of you hog gurus can help me out
Basically i am trying to run my Road Hog Full Boar via artnet to a hippotizer V3 Critter
Being the critter it is a smaller version of the V3 and does not have a direct DMX in, therefore must be run via Artnet.
I am totally inexperience in running hog Ethernet systems, and to be honest reading the manual made my confusion worse.
Anyone done this? or have any tips/tricks for me
Harro
  • Hi,
    I think the HOG is the lightingsystem that you require the least possible knowledge about ArtNet to have it working.
    Just open a new show, patch the Hippo from one on DMX one and make sure they both have IP Adresses in the same range and it should work.
    Give that a try and then ask again :)
    Good luck
  • Harro,
    I thought I would also add some useful information to your questions.
    Here's a little guide:
    Connect console (Fixture-Link) and Hippo with a network cable.
    On the console:
    - Patch the Critter (1x Master + 4x Layer)
    - Make sure your Fixture-Link Adapter is set up correctly
    (i.e. IP Address 2.0.0.2, Netmask 255.0.0.0)
    On the Critter:
    - Go to the Network Adapter settings of your Critter and make sure
    they are the same range (i.e. 2.0.0.10, Subnet 255.0.0.0)
    - Open the DMX Component in Zookeeper and make sure it's set to
    Art-Net and that Subnet and Universe settings matches the settings
    in the console (Art-Net Outputs)
    - If the Hippo sees the Art-Net you will see the status and data
    package info in the DMX component window, sometimes the Hippo and/or
    console needs a restart
    Tip: There's a custom Hippo wheelset which you can import. You can find
    it under Setup, Preferences, Import)
    I hope this helps. If you need more detailed information to any of the steps
    please contact me directly at Jens.Hillenkotter@barco.com.
    Regards
