DL3 Collage and Pallets
I'm guessing this will be more about the Console than the DL3...
Hog 3.1.9
DP2000
I setup a 2x1 collage completely.
I wanted to 1st save it to a Pallet (with the CAL grid).
Record Beam, USE P, USE C, USE B, Select Beam 1 in Pallet.
(contains both Motion, Global, and Graphic 1)
After naming that pallet,
Record Enter for Cue 1 in my Cuelist.
(with the cal grid showing)
Go on to program a cuelist of video.
All is good.
Next day, bring up the system.
Roll Cue 1
Grid alignment is slightly off.
(Tilt on one fixture may be a bit loose, no problem.)
Tweak the Keystoning on right DL3,
(the one used in Cue 1)
Select MERGE on the prompt.
BLIND the console, and it reverts back to being slightly off.
Do a View Cue on Cue 1 and confirm it is referencing the Beam Pallet.
Hmm?
Had to move on, so I ended up merging the change into Cue 1.
  • Yep..
    I have found that selecting the DL-2/3 fixtures,then selecting the required palettes and ,change the required attribute then use "touch" to grab all the relevant masks/pareters and then record back onto the same palette using "replace" rather than update or merge to be a more accurate and reliable method for updating palettes with DL-3/2 fixtures.
    Even the slightest movement or change in pan/tilt values can make all the difference with the DL2/DL3 fixtures where as it's not usually as apparent with moving lights on a day to day basis.
    I found the console was not always able to update the palettes that had more than 2 parameters such as colour,beam,intensity accurately or at least every time i wanted to do something.
    You could test this by making a copy of the pallette and altering it to see which method is more accurate merge/update or touch/replace.
    This was just my workaround,i guess trying to see if the fixture needs to calibrated would also be be a good starting point.
    This was a few s/w versions of both the fixtures and console so things may have changed.
    Regards C
  • I've never had a problem using MERGE to update IPCB DL palettes personally, and yes I too TOUCH all parameters for Motion and Global with both selected at the same time (but never GFX layers in my collage palettes).
    I use the MERGE key with masking though instead of the RECORD key + prompt as it is much faster to update palettes.
    Don't forget that if you didn't have a value for a parameter in your palette when you wrote the cue....adding that parameter to the palette WILL NOT update the cue......you will need to re-select the palette and merge it into your cue again if you add parameters.
    Hope this helps. :)
  • When I'm rested I'll get the show CD out and load it into HOG PC.
    More for curiosity sake.
