Continious color change
Hi all,
I want to make different cue list with color chases.
Here is a example:
I made 2 cue lists:
- cuelist 1: cue 1: first fixture blue, second ficture red
cue 2: first fixture red, second ficture blue
- cuelist 2: cue 1: first fixture yellow, second ficture green
cue 2: first fixture green, second ficture yellow
Both cuelist should play continuous till the other one is triggered.
I tried this with the follow command in the cue lists. The only problem is that stomping isn't working then. They told me it's u bug in this post. It's only happening when the last cue is set as follow.
Is there an other option to create it?
I hope someone can help me because I'm really stuck.
