Newbie trying to program effects
Hi all, I am attempting to program effects on a Road Hog. I want to create an effect that the lights start pointed straight down then tilt up facing the audience and panning back around to the stage. I have my fixtures (8 Mac 2ks) seperated by odd and even and the even ones have the Pan inverted. I am able to easily record this as a cue but is it possible to record this to an effect palette so I can have it repeat itself instead of just being a single movement to its ending position?? Also when creating an effect to program movement are the only options using the various sine waves or can the console track your movement and then you some how make the movement repeat how does that work? Hope this makes sense.
  • Hi Andrew,
    The easiest way would be to program it in a list then add a LINK CUE at the end of the list to the 1st Cue
    Otherwise (I'm struggling trying to think this through properly atm) but MAYBE put a RAMP on both the Pan and Tilt with the Tilt being offset by 180deg
    Good luck!
  • Thanks for the tip I tried and was able to get a better grasp of using the effects engine. Although I found a better way to explain the situation. How could I program the lights to move in a different path to their final position say for instance instead of going straight their the lights circle around to the final pan/tilt position?
  • i think i get what your saying... so your saying 8 lights pointing on the stage... tilt up into crowd... then you would want them to partially circle back around to the final position??
    if so sounds to me like you would make an effect that does just that, then (and for the life of me without being on my console at the moment i cant remember) tell it to play the effect only once with no repition..
    anyone correct me if im wrong, without my console and lights im pretty much useless
  • [QUOTE=whitleyrichard;57459]i think i get what your saying... so your saying 8 lights pointing on the stage... tilt up into crowd... then you would want them to partially circle back around to the final position??
    This thread is from July.... I think his show is over.:rolleyes:
  • i was bored this morning.. didnt even pay attention to the date :sad2: maybe itll help someone else...
