Bug Report (b3148) Copy Frames
WH3+DP8000
When I copy framing values using PIG+Copy and PIG+Record the desktop crashes, but can be restarted using PIG+Open+Backspace.
The same happens using basic copy&paste with mouse.
  • This might be more like H3 console bug, cause in PC copying seem to work.
  • Ah yes. Hog3 only. Just got back behind a H3 this morning and sure enough this reproduces. I am logging a bug right now. Thanks for the report Sami. I don't know if this will get squeezed into 3.2.1 or not. We want to deliver the patch by the end of the week as it contains lots of valuable fixes and every new defect we take on extends our development and test cycle but I'll see what I can do as it seems to occur with right click copy/paste as well.
  • This will be fixed in 3.2.1.
  • Great!
    Btw, have you noticed intensity wheel buttons don't work for the last fixture if you type a selection like a fixture + a fixture.
    If the selection is a fixture thru a fixture none of them get intensity.
    The intensity wheel buttons don't complete the selection like the wheel does.
  • Sami
    Thanks for the information.
    I have logged this as Bug #15432.
    I am not sure if this will make it into the 3.2.1 release.
