I have the same Enttec box and it works with a PC. and any DMX software. It is just a matter of setting up the network. I use it to control LD assistant visualizer with my Hog PC system. However the new LD assistant releasing any day now will work with Hog PC and grand MA directly just like WYSIWYG so will not longer need the box. With that new release, WYSIWYG will slowly fade away. Autocad always has dominated when doing plots. Now it will dominate visualization as well. Vectorworks is a joke.
I wanted to know, if DMX USB PRO INTERFACE ENTTEC is COMPATIBLE WITH THE SOFTWARE HOG 3 PC. THANKS!
yes, it is. and no, it isn't. depending what exactly is the question you want to ask: 1) if you have a hog3pc system including a dp8000, and you want to expand it to a few more dmv lines - yes, it is. 2) if you have a computer and no dp, and want to use the enttec as the only output - no, it isn't.
Marcin, that is not correct. If you use an Enttec ODE Artnet to DMX box with a DP8000 then you can get an extra universe. You cannot use a USB to DMX interface from any manufacturer other than FPS to get DMX from Hog3 PC using the USB port.
