v3.2.2 on IPC Big Bug
Just want to check im not doing something silly here, on v3.2.2 thats just come out, it appears that when recording a cue in blind mode (as you may often do on the fly) the cue you record contains what fixtures you're trying to record, but absolutely no information for anything relating to any of those fixtures? only in blind mode however?
I only discovered this when doing some programming with WYSIWYG, so havent tried it in the real world yet, but that seems like a pretty massive bug if it is not just me being moronic? especially if you did not know it was a bug, as youd record a cue, press play and you'd go to a complete blackout?
Thoughts/Opinions?
Cheers
