effect zero size bug V3.2.3
So if you select any fixture, goto the effects editor, and just press set on SIZE, and type in 0, it will automatically fill it with the largest possible value. It previously just went to zero, so you could in theory busk in an effect... not anymore. Doesn't work on any perimeter.
V3.2.3 on H3
