Mark Cues and other weirdness.
Hello All.
Running RHFB v.3.2.3 (b 3367)
I am having trouble with Mark cues on this version. Does not seem to matter what fixture type or brand so I do not think it is fixture library related.
If I program a split color into a cue It will playback fine unless I mark the cue. If the cue is marked it will playback as a solid color and not the split color. This also happens on certain gobos. It will playback as recorded unless marked. If marked it will pick the gobo in the previous slot.
Also new on this version, Having trouble with color pro FX. Unable to program twinkle wheel. The twinkle parameter cancels out the beamfx and vice versa. Worked fine in previous versions.
Kevin
