Patching to a 16bit dimmer?
Hello,
I'm after a little help with patching please.
How do I patch a 16bit dimmer? The stock dimmer seems to be just 8bit and I don't see how to build my own 16bit dimmer personality as the builder forces me to assign 0>255 to both channels and will not allow the 0>65535 option to be used.
A bit of advice would be most welcome.
Thanks in advance.
Colin
  • Well I jumped the gun slightly posting on here.
    Found out what I was doing wrong with the fixture builder and have now resolved my own issue.
    I just wasn't linking the two channels with the 1/2 command in the first column. As soon as I did that then the 0>65535 option was accepted.
    If anyone else ever has a similar issue, this is the link that helped me.
    www.dry-hire.at/beschreibungen/High_End_Systems/Wog/Wholehog3FixtureBuilderGuide.pdf
    Cheers
    Colin
