5th june 2012
RHFB v3.2.3 (3367)
USB Expansion Wing
Sperwidget
Artnet Output>Catalyst
Hog III PC (Win 7 pro) (3367)
I'm seeing an issue where if i edit/patch/program on Hog III PC and then transfer that backup showfile to a RHFB and expand the showfile,the console does not output any DMX,only thing that i can see is the GM flash button flash's blinks on the RHFB.RHFB GM will show 100% as will the Output levels and the console looks active but without any actual DMX/Artnet output.
Simple fix is to log off/on but a bit odd that the console cannot expand a show and then becomes inactive.
Best C
