I have recently upgraded a Hog 3 Full Boar to os 3.2.1 I have a show that will load in version 3.1.x, however, when I attempt to load the same show on any system running 3.2.x (I have attempted on the full boar as well as hog3pc) I first get a "show server init failure" message and then "show server not responding." I have attempted continuing to "wait" for the show server to respond for over half an hour but it will not load.
I would really like to run this show and not have to downgrade the full boar back to 3.1.x.
Additional notes, I am running the Full boar on a network with an external DP 8000 the internal DP is not used in the show. Other show files that were created and ran in 3.1.x run as normal in 3.2.1. Also I am able to load the show in Hog4pc as normal. I have attempted to load the show in multiple instances of 3.2.x on Hog3PC from 3.2.1 to 3.2.5 and it produces the same errors.
Any assistance would be greatly appreciated.
Thank You
-Andrew
