If I update my RH3 to the new 3.2.6 software, can I download the RH4 fixture library? If not, what do i need to send to have a profile made? (Version of RH, what kind of fixture, etc.)? Thank you
i need a profile made i have look in the hog support fixture libraries and i could not see it if anyone can make a profile for AVE LED-PAR64B lighting fixture
Hog 3 libraries are not compatible with Hog 2. This article might be helpful support.etcconnect.com/HES/Consoles/Hog_2/Software_and_Programming/Fixture_libraries_on_a_Wholehog_2
Can I use a Hog 4 Fixture Personality for a Hog 3? I have a client that has a Hog 3 and just got some new fixtures and they are not in the hog 3 library.
This is why I'm hesitant about buying a hog console I work with many venues that have hog 3 consoles I've tried to build profiles to no luck this is why alot of us are recommending different consoles.
To those who are feeling challenged with fixture creation on WH3 these days, I understand your problem. We did support WH3 fixture creation up until just last year, 8 years after the discontinuation of the product line, and had to stop supporting these as we changed the format of fixtures in Hog 4. Sadly, it is not possible to provide unending support for products ad infinitum and this adjustment for Hog 4 meant the end of WH3 library creation. If you are looking to replace a WH3 product, I would recommend that you take a look at the Hog 4. For those who are comfortable with the WH3 way of working, this would be an easy transition, and it would bring with it support for modern fixture types. Hog 4 PC is a free download from the High End Systems web site.
